hello,againg i did the spark test as i was told and i did saw spark when trying to start.this is a 1972 johnson 2cycle 2hp motor(manual start.pull).now i am comfuse with the oil fuel mix,please bare with me,i am a newbie at this.the instruction on the motor is :1/6 pint(1 to 50 ratio)to a gallon of regular gasoline,now the 2cycle oil bottle i got is 8OZ,how much of the 8OZ do i put into the gasoline gallon?.also there is a low speed an a high speed knobs.turn left for rich and right for lean,the question is how much do i turn these knob to L/R.if i turn all the way to left side the knob get unscrew?.i am trying to make this motor run and after doing the spark test the only thing i can think is oil/fuel mix,i keep pulling and pulling and motor will not run..<br />i thanks you for any answer
