Diff between Johnson 20 and 25?
Bearcamp
I have 2 1970 Johnsons. 1 is a 20 hp and the other is a 25 hp. What's the difference between the 2 as for as the 25 having 5 more horse. Is it just the carb?
dolluper
Re: Diff between Johnson 20 and 25?
reed openings and pistons different
Chinewalker
Hi Dolluper,<br /> I was aware of the reed stops being opened up more on the 25, but how are the pistons different? I've had several of both models apart and didn't notice anything obvious between them....<br />- Scott
G DANE
I'v been told that the pistons were higher on the 25 adding compression, too the reason the 25 had extra weights riveted on the casted cranckshaft weights.
dolluper
I stand corrected I should have said con rod
