Hooking up tach on Johnson 95 SPL
sanmarc
I recently bought a 95 Johnson 112 SPL off eBay and bought a tach for a 96 115 by mistake. The tach has a plugin on it and my control box has loose wires for the tach (3 wires). Can I cut the plug off the tach and hook wires so as to use the tach and foregoe the system check hookups? Or do I need to get another tach. I can send pictures of the tach if it helps.
Joe Reeves
Re: Hooking up tach on Johnson 95 SPL
Tach wires =<br /><br />Black = Ground<br />Purple = 12v when key is in ON position<br />Gray = Sensor<br />Blue (If it exists) = Instrument light<br /><br />The plug is for convenience of installation but it can be eliminated if need be.
signfinder
I bought one of those on ebay too and can't get it to work. Mine in a Lund brand. I tried to hard wire to a 1983 35 evinrude and it won't work..Any different ideas?? My plug has 8 o 9 wires..
seahorse5
Here is the wiring configuration for a System Check tach.<br /><br /><br />If you just want to use the tach function of the gauge, here's the pin configuration (looking at the back-side of the gauge, holding it upright):<br /><br />1-2-3-4<br />8-7-6-5<br /><br />Purple wire goes to pin 1- 12V<br />Black wire goes to pin 2- grnd<br />Gray wire goes to pin 3 - tach<br /><br />Grounding these pins, will activate the following:<br /><br />Pin 4, turn on no oil lite<br />Pin 5, turn on low oil lite<br />Pin 7, turn on check engine lite<br />Pin 6, turn on hot lite<br /><br />Pin 8, is used to activate the warning horn, it supplies a ground to the horn circuit when any other warning circuit (pins 4 thru 7) is grounded
sanmarc
Thank you Joe & seahorse. After getting so many answers from local marine dealers (basically said the tach would not work with my motor) it is really great to get your input - and so quickly! I will wire the tach this morning and post back re how it works today.<br /><br />signfinder - my tach is a Lund too so will let you know how it goes. I will match & label the wires per seahorse's pin config - then cut off the plug and connect to the 3 wires coming off the control box.
seahorse5
To make a neat and easy installation, order the 8-pin connector, wedge,seal, and the 3 individual socket terminals from your dealer. Then wire it up.
sanmarc
Have the Lund Tach installed and is working fine. Pin 1 is RED;2 is Black; 3 is Grey (on the plug). Snipped these wires and connected Red to Purple; blk to blk; and grey to grey. Left the rest of the wires hooked to the plug. Set the little dial in back or tach to point to 4cyl. Seems to register idle a bit high - at 1500 rpm(idled with muffs on) Will find out later on the water how it reads.
sanmarc
Had a glorious day with the wife at Lake Berryesa - and the tach seemed to work correctly . Idle was at 1200 rpm and WOT was up to 6200!! Am I right in assuming 6200 is high? Shouldn't WOT be 5200? Motor sounds fine at 6200 and before I had the tach I ran it WOT all day with no problems. Boat's at 47 mph at WOT. Is that good for a 112 SPL? Has a 115 Merc Inline 6 that leaned out on me and it only did 43 mph. Will I toast this motor at 6200?<br />Thanks.
sanmarc
That should read "had a 115 Inline 6" not has
seahorse5
I'm not familiar with the LUND tach, but an outboard tach is usually set to the "alt" or 6 pulse setting for your 112. The J/E factory tachs only have a 5 and 6 pulse settings on them.
Indymike
Assuming Lund tachs are made by someone else here are a couple places to look for proper settings<br /> teleflex<br /><br /> faria <br /><br />Mike
sanmarc
Set the tach switch to 6 cyl and it seemed to read better - idled at 1100 rpm vs 1500. White caps on Lake made it too choppy to go WOT. <br /><br />Signfinder - did you try hooking up your lund tach the way I did?
sanmarc
Aha! Yesterday I crawled under the dash with a light and low and behold on the Lund system Check Tach there is an Arrow on the little dial. The 6cyl setting is actually where the slot is pointing - the arrow is pointing at 6P. Tach works correctly with arrow pointing at 6P. You are giht Seahorse...thanks again.
ob
Just for future reference glastron1,the 6P denotes the number of alt poles of the engines charging system,not the number of cylinders.
sanmarc
"Alt" meaning alternator, right?
signfinder
Yes I hooked up the tach as you said and it works nice. I took the plug apart and had some ends that slides right in them that makes a nice neat job. thanks for the info
ob
That's correct glastron1.
