1.Starts and idles fine.Will run to about 1/4 throttle if edged slowly,and die immediately if accelerated hard.Pulled choke lever when accelerating and runs fine ? Can't see or find any air leaks on lines,could float level cause this ?<br />2.Should there be sign of battery charging at idle or does the charging system only kick in at higher revs ?<br /><br />Thanks in advance
