Re: No Spark
Remove spark plugs. Rig a spark tester whereas you can set a 7/16" gap. Spark should jump that gap with a strong blue lightning like flame.<br /><br />If no spark, remove black/yellow wire from powerpack, then retest spark.<br /><br />If you now have spark, you have either a short in the wiring harness, or a faulty ignition switch.<br /><br />To test the switch, reconnect the black/yellow wire to the powerpack, then disconnect that same black/yellow wire from the ignition switch. If you have spark, the switch is faulty.<br /><br />Keep in mind that your engine must turn over at least 300 rpm in order to generate spark.... a slow cranking engine usually produces no spark.
