Re: 1965 Johnson Outboard
Hi A.J.<br /> Your motor has needle bearings at the connecting rod to crankshaft journals, but it has bronze babbit bearings at top, middle and bottom crank journals, as well as at the wrist-pin end of the connecting rods. With that in mind, I would definitely richen up the oil mixture. Maybe not to 24:1, but definitely somewhere in between. I run my "mixed" motors (ones with a combination of steel and bronze bearings) at 32:1. What the factory recommended and what works in practice is not always one and the same...<br />- Scott
