Indexing Spark Plugs
qapd
Why did my mechanic put an index mark on the spark plugs? What purpose does this serve. The mark lines up where the wire attaches to the plug base. What gives here, I have never heard of anything like this before.<br /><br /><br />QAPD :rolleyes: :rolleyes: :rolleyes: <br />Pasadena, Tx
R.Johnson
Re: Indexing Spark Plugs
This was the correcr procedure on the OMC Ficht engines. I don't know if this needs to be done on the newer engines. It had to do with how the plug indexed with the injector nozzle.
qapd
Engine is 1998 Johnson 150hp Ocean Pro. It has carbs, no fuel injection.<br /><br />I noticed this weekend while fogging the engine.
Spark plug indexing is a process of orienting the plug electrode in a specific way to promote optimal combustion and flame travel. Its been used in performance tuning on cars for years.
qapd
Dhadley,<br /><br />The plugs are QL78YC. Are these correct?
walleyehed
I'm not DH of course, but those are the correct plugs.(to the best of my knowledge according to the book) :D
Dhadley
Yep, thats fine. I use the alternate QL77JC4 in mine just because they are a tad cooler but youre fine. Just make sure to stick with 87 octane. And dont lug it. 5800-6000 with an average load.
Cricket Too
I've always done this on my Ficht, but is it worth it to do it on a carbed motor, and if so what is a good way to index on a carbed motor?
walleyehed
mm, you have an injector shooting fuel straight in the direction of the plug, but in a carbed version, the fuel/air mixture is in a swirling pattern when spark occures and I don't "think" plug position has any advantages, especially on the fixed-gap plugs.... :D
D
DJ
Guest
Think about it. A surface gap plug would show NO advantage by being indexed, as walleyhed suggests.
DHPMARINE
DJ correct about surface gaps .Depending on the fuel octane,temp,rpm,etc.,there are advantages as to where 'gappable' plugs point.Problem is ' we' will never do enough testing to know if it helps.That's why we listen to them.Sometimes.<br />Injection is a whole other story.Strange that FICHT engines needed a new plug we never heard of.<br /><br />DHP
seahorse5
DHP,<br /><br />I'm not sure of what you mean about FICHT having to use a new plug that we never heard of.<br /><br />Can you say the same thing about the Optimax, HPDI, and 4-strokes that all use "new" or special plugs that we haven't heard of before?
