I am in the middle of adding a 5" extension kit to a late model Johnson 25hp 2 stroke. Going from 15" to 20". I see I will have to pull the powerhead to install the longer shift shaft. I want to make a 5" extension up out of another shift shaft and a coupler. The shaft is the same diameter as what is on a 9.9 johnson. I thought I could get a used upper shift shaft for a 1985 and later 25 hp, cut it down to 5" and use the brass two bolt connector like off a 9.9 or a 15 omc motor to join to the existing shift shaft and save pulling the power head. Anyone ever tried this? comments please
