What is the year & HP of this motor
bencat
A friend of mine has a old Evenrude Outboard and is trying to find out it's year and HP. The Serial No. is 752216184. Can anyone help, Thanks, Ben
bubbakat
Re: What is the year & HP of this motor
We need the model number to determine this ben
OBJ
If the number posted is separated, please post.<br /><br />The 7522 part of the number relates to a 57' 7.5hp.
bencat
I had the number wrong, Sorry, it is 7522-16814. Does this help Thanks Ben
Paul Moir
Like OBJ said, you've got a '57 there bencat.<br />Evinrude Model 7522<br />Year: 1957<br />HP: 7.5<br />WOT RPMS: 4000<br />Displacement: 12.4 cu.in. = 203.2 ccm<br />Cylinders: 2<br />Weight: 59 lbs. = 26.8 Kg<br />Gear ratio: 15:26<br />Spark plugs: Champion J6C gapped at .030" (J6J is no longer available)<br />Fuel/Oil mix: 24:1 87 octane gas to TC-W3 rated outboard oil.<br />Lower unit oil: OMC/BRP 'HiVis' or equivelant 80/90W outboard gearcase oil.<br /><br />Athough those 7.5s are great engine they're known for throwing a rod if heavily abused. Stick with the 24:1 oil ratio and never rev up the engine in neutral.
OBJ
Thanks Ben.....it's a 57' 7.5hp. Double hose fuel system. Fuel mix is 24:1.<br /><br />Plugs are a Champion J6C set at .030.
bencat
Paul & OBJ, Thanks for the reply, you guy's are the ticket.
