looking for a used motor
llfish
I have a 17.5 ft. Lowe bass boat pushed by a 87 Evin rude 50 Hp motor. I am looking at buying a used motor to rebuild and install on my boat. Max hp is 90. Any suggestions as to make and year would be greatly appreciated.<br /><br />Looking for something easy on fuel, strong motor that does not need a lot of fine tuning to keep it running.<br /><br />Any suggestions will be appreciated.
Solittle
Re: looking for a used motor
Go to the brown tab at the top of the page - "Boat Motors".
ledgefinder
Ensign
Is the 50 not enough? <br /><br />On the OMCs, the 50-60hp twin (40 to 40+ cubic inches) is a good motor. Needs to be spun to make power (not much low end). In my experience, the HP rating on these might be a bit optimistic. Good fuel economy.<br /><br />The 60-75hp triples (50 or 56 cubic inches) have a good deal more beans than the 50/twins. More low end, though they will wind out on top too. Decent fuel economy. <br /><br />At 85/88/90hp, you can get into the 100 cubic inch V4s. These will 'feel' a lot stronger than the triples, AND will drain the gas tank a LOT faster.<br /><br />Be aware that HP ratings changed in 1986. A 1986 90 is same as a pre-1986 115, etc..<br /><br />I think the picks of the litter are the 70hp triples, or the 1986+ 88SPL, depending on how much you value power versus fuel economy. Both are great motors. <br /><br />The 88 has a really sweet powerband, and probably the best reliablity record of any larger OMC outboard. The 90 is the same motor, but with VRO. On the V4s, I would not go earlier than 1986, simply because the earlier 85/90 V4s are too detuned on top for all that gas they use. On a heavy cabin cruiser, good choice; but on a Tenn bass boat, you deserve some top end.<br /><br />On the triples, there's no reason not to buy an earlier one - back as far as the 1973 65hp, first year of mechanical shift. If you want power tilt, stay with the 1979 or later; the earlier power tilt units are a little flaky. <br /><br />Keep an eye on the middle cylinder compression on the triples - if they run lean or hot, that's where they often fail first. On either motor, compression should be with 8psi, highest to lowest, across all the cylinders. Ideally just 2 to 3 psi variation.<br /><br />Enjoy!
ledgefinder
Ensign
If you've got other things to spend $ on, I should probably add that the Merc 50hp 4cylinder is a great motor as well - and inexpensive. Notably stronger than the OMC 50 (in my experience), and smoother. Troll dead slow all morning, ski WOT all afternoon. Watch the impeller.
llfish
The 50hp was just fine. Got me there and back with out any trouble. Problem is someone placed ball bearings in the cylinders and lower unit. Shot craps when I started it up. Looks like someone took a ball ping hammer to the pistons. Lower unit gone to. Any way can not turn it over by hand.<br /><br />Thanks for all of the info. Really helps!
G DANE
I think, like ledgefinder, a tripple looper will make you feel you've got a brand new boat. I would advise you to get a late eighties, IMO best period of OMC's apart from now, Bombi days.
llfish
Thanks G. Dane. All ways nice to have a second opinion.<br /><br />Thanks<br />Larry
