Re: Honing the cylinder
Maybe we need to go back a step or two instead of focusing on the initial question about honing.<br /><br />Salt water can't get into the piston because the piston is a solid object that just sits in the cylinder. Did salt water get into the cylinder? Or the block below the piston? Or both?<br /><br />Seizing is a different issue to just light corrosion on the cylinder walls. If the rings were seized to the walls by corrosion it's a pretty serious bit of corrosion and the rings and ring grooves probably need attention. The bore, rings and piston may have been scored or otherwise damaged by corrosion or extracting the seized piston. <br /><br />If the piston was corrosion seized to the cylinder the con rod top and bottom ends might be damaged as well. Along with any other part inside the motor.<br /><br />I'd get the piston and the cylinder professionally inspected to see what needs to be done before going any further.<br /><br />How did salt water get into the block or cylinder? Immersion or something else? If it's something else a hone ain't going to fix it.<br /><br />A mower shop is as good a place as any to get it all inspected.Originally posted by Bozza:<br /> My engine seized because salt water got into the Piston. I pulled apart my motor and Pulled out the rusted Piston.
