Lower unit swap?
Bearcamp
Will a lower unit from a 1965 15-18 hp fit on a 1970 20-25 hp? I know it looks the same,BUT?
WillyBWright
Re: Lower unit swap?
They used that gearcase for a long time on 18s thru 25s. I expect it would fit fine. Later ones up to 28Hp had splined propshafts, but I think they'd even work. Johnson, Evinrude, and Gale (Sea Kings, Buccaneers, etc.).
Bearcamp
I've been lookin for a lower unit for my 1970 20 hp and there's one on ebay, auction number 451701072. He states it's 1963-1965 for 15-18 hp. It's the one I was wondering if it'll work.really all I need are the gears and clutch dog but new is arounf 300, WOW.
Chinewalker
Hi Bearcamp,<br /> Yes, you should be able to make it work. If you attempt to use the earlier gears in the later housing, you may have some depth issues in regards to the pinion gear as I think they changed the thrust washer & bearing arrangement somewhere in there... But, the early unit should work as a whole.<br />- Scott
WillyBWright
The new gear kit is a vast improvement over the old one. It converts easily, but almost none of the old guts go back in. It has a locking mechanism that helps keep the gears engaged. Before they wore the engaging cogs if the shifter was out of adjustment. The new system outlasts the old by at least 3 to 1.<br /><br />If you get that gearcase off ebay, it could have the same problem as your current one. If it hasn't had that gear upgrade, that's a major possibility. If it has, you might be able to swing a pretty good deal.
