Head Gasket Part Number
TTravis
I am working on a 15HP Johnson Model J15EE0D serial G 03889658 year 1995.<br /><br />I need to order a head gasket, probably from my local NAPA store but my catalog only goes up to 1992 for the head gasket listings.<br /><br />I believe what I need is NAPA part 18-2963 which replaces OMC part 330818. This is what they show for the 1974 to 1992 model and the picture looks like it might be the right one.<br /><br />Can someone please verify that this is the correct head gasket for my motor?<br /><br />Thanks in advance,<br /><br />Tom Travis
DHPMARINE
Re: Head Gasket Part Number
Tom,I would got to my local Johnson Dealer,but if NAPA is where you go,use their current catolog.By the way,they also do wine? GRIN !! <br /><br />DHP
Paul Moir
I belive 18-2963 is only for 9.9s and 15s up to '92. The current (05) catalog says it's only for '74-'92. It doesn't give any part numbers for '93- .<br />Looks like you're going to have to make a trip to the dealer or order one from a Johnny/Rude dealer:<br /> Mastertech
TTravis
Thanks guys. You are right as usual and you prevented me from ordering the wrong part based on an assumption. NAPA does not cary this part. I was able to get it at my local dealer OMC Part # 338222 for $14.26 which is different than the head gasket for 92 and earlier.<br /><br />Was 1995 a unique year for these 15 hp motors? What years did they produce the same style motor I have?<br /><br />Tom Travis
marinemech
1994 until 2005<br />the 93 had a smaller bore
TTravis
Thanks MarineMech.<br /><br />I have some more questions about this motor. I had a "friend" take this motor and say he would fix it a couple years ago. He recently moved, and when he did, I got my motor back with a lot of loose parts in a box. He tried to remove the powerhead but did not get far. The problem was that the pistons were locked up. I originally thought the engine got overheated but how I think it got backed down a steap ramp and got water in the pistons. Anyway, I need to know the bolt sizes for the following because I am going to have to go out and buy new ones.<br /><br />What size is the 6 bolts to bolt on the cylinder head?<br /><br />What size is the 6 bolts to bolt on the power head?<br /><br />What size is the 6 bolts the bolt on the lower unit?<br /><br />Is there anything special about these bolts? I assume they should be hardened automotive bolts that I can get at the local NAPA store.<br /><br />Any advice would be appreciated.<br /><br />Tom Travis
DHPMARINE
I can't tell you the bolt size,but I'd go to a dealer and buy original replacements.In some cases they use a smaller wrench size (for easier access) or a flanged bolt instead of a washer,sometimes an insert of thread-locking material,etc.<br /><br />DHP
