Johnson 25hp identification
dbighook
Any help appreciated. Trying to indentify correct year of Johnson 25hp motor.<br />Model # J25TELCSA<br />Serial #B5266229
jfm1
Re: Johnson 25hp identification
I think this is a 1980 #J25TELCS
dbighook
Thanks for the response. Curious why you say junk it though. Motor given to me by friend. Although last started 2 yr's ago. My attemp to start failed. Would only get it to run while spraying starting fluid into throat of carb. Was planning to order gasket (overhaul kit) for carbs.
BoatBuoy
dbighook,<br /> "Fix it don't( Junk IT)" is merely jim's signature line and appears at the bottom of all his posts. It's not meant for you.
jfm1
don't use starting fluid from what I've read on other post that could harm your motor. they say to use a gas oil mix in a spray bottle. Good Luck
G DANE
Those eighties twins were strong reliable motors, same block used up to todays outboards, close to same ignition too. Clean and rebuild the carb, Clean all electrical connectors, including ground connections. Change water pump impeller and gear oil, observing if the old is milky from water intrusion. Change spark plugs to new Champion QL77JC4. All chances are you got a good motor. ( And a good friend )
