"73" johnson 9.5 is it worth saving???
i have recovered a 73 9.5 jonny outboard manual start. this engine was submerged in freshwater for about 6 hours last october and has not been touched since then. it is still in the garage sitting upright in the corner.i have not opened the engine up,to see what damage is inside yet. i was told it was a 2 pull starting engine, that ran very well and was reliable.is the engine worth repairing given its age and parts availabilty or passing on to a friend.
roscoe
Re: "73" johnson 9.5 is it worth saving???
Age or parts availability are not the problem.<br />Its the lack of immediate attention after recovery, and the cost of those parts.<br /><br />I would sell the lower unit, tiller, cowls, carb, etc, on ebay. Recycle the rest of it.<br /><br />It might be do-able, but I think you will need to tear down the entire powerhead and inspect/replace too much.
Chinewalker
Hi OMOTR,<br /> If the motor had been properly taken care of after its dunking, then it would certainly be worth repairing and using. However, if it has been sitting since October with water inside and out in the open air, then it it likely junk at this point. As Roscoe pointed out, the whole motor isn't junk, but the heart of it likely is. The typical weak point on those motors is the lower unit, so you might be able to scrounge up a lower unit-less motor without too much trouble. This is a good time of year to hit the marinas, as they're usually not running full tilt and might be more willing to accomodate someone looking for 30+ year old stuff....<br /><br /> Go Steelers!<br /><br />- Scott
AaronG
Just as Chinewalker said, I have an early 80's evenrude 15 with a bad lower end. If the parts are compatible, I'd be willing to let you have it cheap.
Chinewalker
Hi AaronG,<br /> The 9.5 is a different animal from the later 9.9/15hp series...<br />- Scott
thanks for the reply's.i thought that parting out the good parts was the only way to go too,but thought i would get some other opinions.while were on the subject,i have a jonny 2000 9.9 manual start,tiller steer.is it worth putting the 15 hp carb on it for more zip?
phatmanmike
the 15 carb wont gain you 5 hp<br /><br />sorry. too many people try this and just get a crappy running motor
thanks again... better to know now,than to waste time and money and end up with a crappy running motor.i have heard of people doing this,but dont know any personally to see if it's a good idea or bad... thanks,now i know better..
BugEyes
If the motor havn't siezed totally you could always try just cleaning the carb, change the plugs and start it. If you get it running until warm it's good again.<br />I did that to a 20 hp Johnson from 1972 and it served my for years after. Even had to knock the pistons loose in the bores with a rubber club and a lot of WD40.
Bearcamp
AaronG, I have a lower unit for that motor. Will you sell? Been looking around for one on my brothers boat.
