spark plugs
Paul Moir
Re: spark plugs
The Q has an inductor in it that functions sort of like a resistor in a resistor plug. <br />What it does for you is lessen radio interference from the ignition system. Without the Q series plug, your VHF radio and cell phone will likely be noisey. I'm not sure if fishfinders react to the interference or not.<br />For the most part, all modern outboards use some sort of radio noise suppressing plug.
R.Johnson
Re: spark plugs
The main reason is to not pick up false signals from the VRO, or what you think would be a signal from the VRO.
tsensat
Re: spark plugs
thanks I wanted be sure it was the same heat range.
