RustynHouston
Thread starter- Joined
- Jan 25, 2005
- 21
this is my first boat and outboard experience-<br /><br />just purchased 77 Evinrude 115 HP that had carb overhaul and new water pump before I got it. I just put on new fuel pump. (compression same in all cyl and good)<br />while running across the lake at set throttle, the engine sounds like it revs up for a while then revs back down. Speed remains the same with no noticeable performance shift. Engine idles and shifts fine. Its almost like the clutch is slipping, but these are direct drive once they are in gear. There is no "clunk" or jerking when the rev up and down takes place.<br />any ideas out there? thanks!
