Re: old 35hp Johnson sea horse trouble
Oh, ok. Before proceeding (or getting a manual even) we've got to figure out what's stopping it. It's possible that something in the lower unit has come apart and is preventing the engine from completely turning. The easiest thing to do is to remove the lower unit completly and see if it then turns freely.<br /><br />Here's how you get it off:<br />Start by removing the rear part of the midsection cover. This is the back part of the large casting that mostly covers the outboard. This exposes a bolt you'll have to get at and makes it a little easier to get at the shift linkage.<br /><br />On the side of the forward part of the midsection cover is a panel held on by two screws. Remove it and the panel behind it. You should be looking at the shift coupler. Put the engine into reverse so you can get at it better, and completely remove one of the two bolts holding it on (don't just loosen it). That will release the shift rod.<br /><br />Now remove the 6 small bolts holding the lower unit on and the one large one on the back (the one that was behind the cover).<br /><br />You can now remove the lower unit. It should just pull off, but it may require a little convincing if it hasn't been done in a while.<br /><br />With the lower unit off, you should be able to figure out which end is binding - the upper or the lower.<br /><br />Tell us what you find!<br /><br />PS - be gentle removing the lower unit bolts - if you snap one then it's going to be a pain to fix. Try 'tapping' the wrench with your fist and applying heat (from a torch) and penetrating oil if you find one that's stuck.
