Re: Johnson slips/cavitates after 35 minutes
Just to add another tidbit to the good help you are recieving,with the engine not running,the fuel primer bulb should pump up firm and hold.If the bulb won't do this then there is a leak in the fuel hose or fittings,the carb needles are not seating,or the bulb itself is defective.Once you install the new ones mentined above,see if it will pass this test.
