imstillatwork
- Joined
- Jan 22, 2005
- 169
How do I get to the inside of the hull on a boat like this? ? http://www.lot-o-nothin.com/lotonothin/boat.cfm <br /><br />The only opening is about 16 inches wide and 10 inches long in the back against the transom.
http://www.lot-o-nothin.com/lotonothin/viewimage.cfm?id=12 <br /><br />I would kind like to check it out, as there is ONE TINY spot about 4 feet from the stern on the starboard side under the water line that appears to be a screw puncture from the inside out. It's very solid, and I can't see through it, but there is a rust spot about 1/8th of an inch wide that I wanted to check out.
