Low idle adjustment screw setting.
tabbott
What is the initial setting for the low idle screws on a 1993 40 HP Rude Mod# TE40ELETB
ob
Re: Low idle adjustment screw setting.
According to your other post tabbot ,you indicate that all is well now with the idle mix screws open to two turns.Are you having further idle issues?
tabbott
No just checking to ensure that its correct or close enough for govt. work.
ob
tabbott,each engine will have its own "sweet spot" so to speak as to the final setting of the idle mix screws.There are suttle differences in exhaust back pressure and and intake air density.My 96 70 hp Rude performs best at 3 1/4 turns open from lightly seated.Another may run well at 2 1/2 turns open.Make sure your carburetor linkage roller is on center and just touching the scribe line of the fiber throttle cam when controls are in the neutral position.This should isure that the carb flaps are fully closed when in neutral and will begin opening in synchronization with the timer base linkage.There should also be individual adjustments for each carb flap.An engine specific manual can touch on all of these critical points in specific detail to your engine.It is the single best investment that a do it yourself boater can purchase.That's why even factory trained mechanics use them as reference.
tabbott
Thanks OB,<br /> I will make it a point to purchase a manual. I've been meaning to do this but this site is always so tempting. <br />tabbott
ob
Good luck to you and feel free to ask away with any questions you may have.Otherwise us die hards don't have anything to do.Except read and learn ourselves. :)
tabbott
I'll do my utter best to keep you all busy.<br />Much Appreciative,<br />tabbott
