Re: 1972 Evinrude yachtwin 4hp overheats
There is no o-ring at the top of the cooling tube. It joins into the adapter plate with a compression fitting. So no, I have to disagree with his diagnosis.<br />Does mist come out of the idle exhaust ports when you run it in water? <br />These engines are easy to work on yourself. Would you consider doing the repair yourself? If there is a clog it will be labour intensive, but the parts are pretty cheap.
