96' Johnson 175EXED compression ??'s
lucy
What should good compression be on this motor,and does anyone out there know its approx weight?<br />Thanks.
lark2004
Re: 96' Johnson 175EXED compression ??'s
90psi and up is good, but more importantly is that the cylinders are within 10% of each other. If you have any major variances between cylinders, then a decarb might be worthwhile.
ob
J175EXED outboard weighs in at 375 lbs.
lucy
Thanks lark2004 and ob for the quick replies...I will get the actual figure when compression test is done and compare to your ballparks.
