Johnson 75
green52mgtd
purchased 63 Thompson wood boat with Johnson 75 OB. What is the oil to gas misture ratioo, or how do I find out
bareden
Re: Johnson 75
more then likely it will be 50:1 ratio about 6 ounces of oil per gallon ... but im not sure..
Re: Johnson 75
50:1 ratio is 16 oz of oil in 6 gallons of fuel or 13 oz in 5 gallons. At 6 oz per gallon you would not be able see where you were going due to the smoke. Mixture ratios are provided on the label of most two stroke oil containers.
Todd Humphreys
Re: Johnson 75
By the way what year is your motor????I have a 1982 Johnny 75hp and 50:1 is the recommended gas to oil ratio.
Solittle
Re: Johnson 75
If that is a 63 motor you need confirm the 50:1 as there is a point where 24:1 was required but I don't remember which year.
