Can up put an electric start on a 1973 18/25 hp evenrude that is currently a pull start?<br />Also is it possible to put a bigger prop on it verses the stock one?<br />Thanks, Herothc2003
if your motor has a toothed flywheel then you can put on a starter if not then you have to get a flywheel you also need a bracket for the starter sorry I can't help with the prop
