Re: '75 115 water pump reinstall
Thats what those two plastic tubes are for. Yours may have slid up on the copper tubes in the midsection. One is longer than the other so you can start one at a time. Just start them in the pump housing and slide the unit on. You may have have someone turn the flywheel slightly to line up the driveshaft splines in the crank.<br /><br />If you buy new tubes, check out the prices. Believe it or not the short one used to be more $$ so we just ordered all long ones and cut one off. May be different now.
