Johnson 25HP no start
jtexfisher
'Mornin...<br /><br />Been trying to get a 25hp to start.<br />To date:<br /><br />1.) Checked spark. Good to both cyls.<br />2.) Cleanded carb. All passages look good, float level ok by the Clymer book.<br />3.) Fresh fuel, good 50:1 mix.<br />4.) Choke being run manually. I've tried with just about every combination of choke I can think of.<br />5.) Timing? Haven't looked. Motor was running at storage 1yr? ago.<br />6.) Compression....should it check like 4 cycle motor? Just look for even pressure in both?<br /><br />Stumped..<br />Jtex :confused:
DHPMARINE
Re: Johnson 25HP no start
Compression check like any motor,look for close readings.If under 70psi,running may be doubtful.<br /><br />Does your choke close 100% ? That is mandatory.<br />Also,spark test.Did spark jump at least 3/16 inch ?<br /><br />What year is this?<br /><br />DHP<br /><br />good luck ! !
OBJ
After checking compression and checking that the choke plates are closing 100%, you might try squirting some premix directly into the throats and see if that kicks her over.<br /><br />As DHP posted, would be nice to know what year this is. A model number would be even better.
jtexfisher
No change with the fuel spray. Still looking through the shed for the comp. gauge!<br />jt
G DANE
Did you ( or someone else earlier )eventually swap plug wires or charge wires to coils ?? When did this motor run fine last time ??
OBJ
GD...his original post said it ran at storage 1yr. ago. Being an electric start, might be worth a try to disconnect the wire harness at the engine and try to pull start it. That would at least eliminate the key switch.
