Fisherman37
Thread starter- Joined
- Mar 17, 2005
- 3
There must be a trick to this. I disconnected the upper end of the shift rod located under carborater on my 1978 Johnson 85 hp. Dropped the lower unit, replaced the water pump and reinstalled the lower unit. Now I can't get the upper end of the shift rod lined up to reconnect it to the lever. Very little room to work and hard to see what I'm doing. Is there a "trick of the trade" for doing this. I hate to think about removing the carborater. I have disconnected the shift cables from the shift levers on the motor in order to more easily move the lever and give me more room but still no luck. Any suggestions would be appreciated.
