1997 Evinrude 90HP Idle too high
columne
With boat in water in Forward gear Idles at 1000 RPM. This 4 Cy engine has orfice type and Idle speed is not adjustable. The thing purrs like a kitten in all speeds and gears. I have a 14X17 prop. Is the prop my problem? High idle makes it difficult to throll and sometimes causes gears to grind when shifting
reeldutch
Re: 1997 Evinrude 90HP Idle too high
check the trothle cable it might be to tight before adjusting anything.<br /><br />your idle should not have anything to do with your prop.<br />when and how did this start.<br />was it sitting for a while?<br />and is your motor getting to normal operating temp?<br /><br />reeldutch
columne
Thanks for your reply. My title says it is a 1997 model built in 1996. Model number is E90SLEVA or it could be E90SLEUA. Hard to tell if the 7th digit is a V or a U
ob
EU is a 97' model.Here's a code for engines from 1980 - on.<br /><br />I N T R O D U C E S <br /><br />1 2 3 4 5 6 7 8 9 0
columne
Well thanks . It appears that I have a 97 model. Thanks and have a nice day
