68 Johnson 33hp
larry55
Can anyone out there tell me where the t-stat is located on my engine? My $30.00 manual is worthless.
DHPMARINE
Re: 68 Johnson 33hp
See,you've already learned something here.The thermostat is under a cover,on top rear of the cylinder head.<br /><br />DHP
Paul Moir
Re: 68 Johnson 33hp
There is no t-stat on your engine. :) <br />I think DHPMarine is thinking of the 40hps. The early '50s 25hp, 30hp, and some 35hp (not super quiets) had no thermostat. The '60s 28hp and 33hp didn't either. They were based on the 30hp and 35hp (not super quiet) engines.
larry55
Re: 68 Johnson 33hp
Originally posted by Paul Moir:<br /> There is no t-stat on your engine. :) <br />I think DHPMarine is thinking of the 40hps. The early '50s 25hp, 30hp, and some 35hp (not super quiets) had no thermostat. The '60s 28hp and 33hp didn't either. They were based on the 30hp and 35hp (not super quiet) engines.
larry55
Re: 68 Johnson 33hp
This makes much more sense. I thought I was going crazy trying to find the the t-stat. Any thoughts why I am not getting water flow with new impeller? Thank you anyway. Larry
Paul Moir
Re: 68 Johnson 33hp
No problem!<br /><br />Do you have the water level up to the impeller housing when you're testing? If that's not it, I'm afraid the next thing is to pull the lower unit and try to find what's wrong. If you can't easily blow up through the water tube, then it's blocked somewhere. You can attach the cut-off end of a garden hose to the tube, held on with a hose clamp to try to blow any obstruction through if it's blocked.<br />Otherwise, is it possible that the impeller key fell out of place? How about having the impeller vanes pointed backwards (they'll normally flip right back over when you start the engine, unless the impeller has been lubed)?<br />The cooling system is pretty simple - not much to go wrong and no really narrow passages. It takes a few seconds for the block to fill up before it starts gushing too.
larry55
Re: 68 Johnson 33hp
Originally posted by Paul Moir:<br /> No problem!<br /><br />Do you have the water level up to the impeller housing when you're testing? If that's not it, I'm afraid the next thing is to pull the lower unit and try to find what's wrong. If you can't easily blow up through the water tube, then it's blocked somewhere. You can attach the cut-off end of a garden hose to the tube, held on with a hose clamp to try to blow any obstruction through if it's blocked.<br />Otherwise, is it possible that the impeller key fell out of place? How about having the impeller vanes pointed backwards (they'll normally flip right back over when you start the engine, unless the impeller has been lubed)?<br />The cooling system is pretty simple - not much to go wrong and no really narrow passages. It takes a few seconds for the block to fill up before it starts gushing too.
larry55
Re: 68 Johnson 33hp
Thanks Paul, I did as you suggested and now I have water flow. Thanks again. Larry
