spot_remover
Thread starter- Joined
- Mar 21, 2005
- 7
i just recently repowered my 14X42 aluminum with a 30hp johnson. my boat has a 15" transom and the motor has a 20" shaft. i mounted it with a T-H Marine fixed jackplate. according to my measurements, i should be getting about 5" of lift but in actuality am only getting about 3" due to the angles involved. i dont want to mount it any higher on the transom because of concerns about strength, but can get about 1 1/2" more lift using a spacer between the motor's mounting bracket and the jack plate. as it sits right now, my cavitation plate is about 2" lower than the bottom of the boat.<br /><br />i have yet to water test this new setup. my questions...<br /><br />in your experience, what will be the result of having the motor 2" lower than it should be?<br /><br />do you think i should add the spacer now or wait till after a real world test?<br /><br />should i just buy a new hull with a 20" transom???<br /><br />thanks for the replies. the boat is going out tuesday regardless, i'm just trying to get a feel for what i should expect.<br /><br />mitchell
