FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
JB ,it is a 1987 70hp Johnson 3 cylinder.<br />I had 25 replys to the old post but it looks like everyone gave up on it.The post about the engine stopping suddenly after running fine all weekend.<br /> I finally determined that the spark would not jump the necessary 1/2" required.I only get about 1/8".<br /> Don't really know where to go next..timing,pickup coil or CDI box?
I read your " Engine quit suddenly after running perfectly " thread, and I dont think its a spark problem. If you are only getting a 1/8" spark, it might cause you an idle problem, but not a "not run at all problem."<br />Just my 2 cents.
Read my last reply to your old thread and clean everything up. Take my advise and keep your thread for future - will give you more help. I dont think this is a crancking speed problem - then it should cranck reel slow. I guess you checked spark with all plugs out - right ? It will spin then.
Basscat 1,<br /> It's spinning like a banshee with a new fully charged marine battery.Plenty of cranking RPM..just no cranking.I'm gonna check the grounds again in the morning,then try it for the hundreth time and then probably drag to corpse to the dealer.I'm tired of screwing with it at this point.I appreciate everyones input.
If you are sure it's a weak spark that's causing your problem, yoiu need to start trouble shooting the ignition system as per the manual. I had a 9.9 Johnson that had the same problem with a weak spark and I traced it to the charge coil under the flywheel. I had to invest in a DVA peak reading multi meter in order to do the trouble shooting, but it still worked out cheaper than taking it to a repair shop.<br /><br />There are some resistance tests that you can do with a basic ohmeter to give you an idea before you go spending money on an expensive tester. The tests are all in your manual.<br /><br />Good luck
Drug the corpse to the shop today..fish are biting and I have two other boats that run.Tired of beating my head against this one.I'll post the final verdict later....10 to 12 days waiting list.<br /> Thanks to all that helped.
