HI<br /> I have a friend who has a problem with his carby, 175 1998 johnson, he has had it back to the repair shop a lot and it is still not fixed. The problem is the overheat alarm goes off and engine slows to about 2000 RPM, sometimes turn off key for 10 seconds or so will fix problem but not always. parts replaced include water pump, thermostats, head gaskets and some electrical bits and pieces. when the alarm goes off (which is entirely random, maybe 1 min use maybe 3 hours) water stream from tell tale still strong and not overly hot,the shop has told him it is hard to fix as it is so intermittant. Any best guesses on what to replace??
