geekomatic
Thread starter- Joined
- Feb 12, 2005
- 136
I've just started digging into my little '58 Fast Twin 18HP. Looky. It has Electric Start,for which I'm quite happy about! I bought the Seloc manual for the thing, and it's done nothing but confuse me even more.Seems like everything on my motor is completely bass-akwards to the decriptions/photos in this manual.I know this isn't rocket science, but I'm getting a little frustrated.I need to remove the carb and check the needles and the floats.I think I have an electric choke,but I'm not sure.What I think is the choke solenoid looks like it's been smacked with a hammer,and will most likely need to be replaced.The rubber boot on the thing is also trashed.Does anybody know if I have a Type I,II,or III carb? Is this,in fact,and electric choke? The Guts.<br />I've taken the lower unit off and the impeller and water pump looked like they were installed yesterday.It's going to be replaced anyway.I know for a fact that the thing has sat uncranked for at least three years.There was NO,absolutely NO,lube in the lower unit,except for a residual coating on the gears.The gears look OK,oddly.<br />I also need to know a good source for the dual fuel lines and fittings to the tank,which is also OK.The fuel lines are dry rotted like nobody's business.I think,overall,the motor appears to be in pretty good shape.I won't feel comfortable cranking it until I've fully checked everything.These things appear to be built to survive a nuclear winter.Pretty happy with it, but I felt some expert advise never hurts.I can post as many photos as needed if one of you gents decides to adopt a dummy for a day or two
