JLOWRYinIL
Thread starter- Joined
- Apr 10, 2005
- 11
Hey guys I did a search and couldn't pin down my problem. Boat was sitting all winter but docked with no problems. She didn't fire right up so I removed the carbs and cleaned them well. No problem. It starts perfect now but has a definite surge at all rpms, obviously more noticeable at lower. Will only idle at about 2300 and when it surges it falls to 800. No gas leaks and pumping bulb doesn't affect. When I pull plug wires, one doesn't affect the way that it runs but it is firing pretty hot from wire. I put that plug in another cylinder and it is fine. Compression good. It sounds like fuel from description but I am almost positive it's ignition. Power pack? Coil? I can't see a way to switch coils without cutting wires to the power pack. Any other tests or ideas? Thanks in advance.
