1990 60hp Evinrude stalls
GaryH
Boat started fine and was running around 3,000 rpm and the motor suddenly stopped running. Tried to start immediately and did not seem like there was any spark at all. After 3-5 minutes motor started and ran well enough to get to a fishing spot. The problem happened about 4 or 5 more times. Sometimes after it died it would start right away, other times, it needed to sit for a few minutes. Seemed like it would only die within the first few minutes of running 2,500-3,000rpm after the engine ran a while seemed to be fine. <br /><br />Carbs have recently been cleaned/rebuilt. Seems like an electrical problem to me. What are the odds it is a power pack problem??<br /><br />Appreciate any help!!!
JB
Re: 1990 60hp Evinrude stalls
Howdy, Gary.<br /><br />Welcome to iboats. :) <br /><br />Sounds like a hot failure in the ignition system. See what happens if you run her with the bonnet off.<br /><br />Most likely suspects are powerpack and stator.<br /><br />Good luck. :)
twoofakind
Hello!<br /><br />It sounds like I have the same engine and the same problem! Have you solved it yet?<br /><br />I have been told the powerpack or stator as well. My stator has continuity across the brown leads, so I'm told it's fine. Not sure how to check the powerpack, though.<br /><br />Let me know if you've had any luck! It's a great engine when it's not stalling! By the way, what do you have it on and what RPMs do you get for WOT (wide open throttle)?<br /><br />Thanks!<br />Mick
