LU to Midsection Exhaust
bm258
1990 Johnson 100 HP (Mod. # J100STLESB)<br />I just replaced the water pump on this motor. When I pulled the LU off the piece that that sits on the LU that goes in to the mid section exhaust housing needs to be replaced. I am very dory for the confusion, but my manual does not mention this part (or i can't find it). form other post it seems the part # is 314937. Is this the right part #? When i order this part will it be the entire assembly, or just the rubber seals. I need to replace the entire assembly. Again, soffy for the confusion, but I am not sure of the part name. Thanks for any advice.
D
DJ
Guest
Re: LU to Midsection Exhaust
Are you talking about the water pump housing?
bm258
no, i replaced the housing already. The part i am taliing about just sits inplace between the midsection and lower unit. the exahaust passes through this piece so that the exhaust can go through the hub.
Walker
I believe its just call the lower exhaust housing.
bm258
is this the correct part # for the lower exhaust housing? 314937 Thanks again for the replies!
