phatmanmike
Thread starter- Joined
- Oct 24, 2003
- 3,869
hello. i have a 1991 225hp sea drive mounted to the back of a full transom 1984 sea craft 20' center console.<br /><br />as it is now, when in the water at rest, the water comes up and over the exhaust ports on the back of the motor and almost to the cowl hood. after coming to rest from cruising, water comes up over the top of the cowl hood, and im afraid i may ingest water into my new motor(to me, its new)
<br /><br />i have a 24" setback with the sea drive, and right now, the anti-cav plate of the motor is about 1" higher than the lowest part of the hull/keel. the boat has a pad, about 14" wide in the bottom of the hull , and it runs forward about 8 feet. the deadrise at the transom is pretty light, id say around 15* degrees<br /><br />i would like the motor to be higher, not just for obvious water getting into the motor reasons, but also to help gain a lil bit in the performance region, too.<br /><br />if i DO/CAN raise the seadrive, i would like to fiberglass over the old holes and such with a new sheet of glass right on top, inside the boat, giving the motor some nice, new , added support, cause this puppy is heavy!
