Trim guage
nedskelly
I have a 70hp 3cyl Evinrude, (not sure of year)engine plate.<br />E70 OTLCIM <br />A366397<br />I bought a trim guage off E-bay OMC outboard trim GP7412B made by Faria.<br />Is this unit compatible with my motor and what are the wiring instructions
OBJ
Re: Trim guage
Hello ratsack and welcome to iboats!<br /><br />Your 70hp is an 81.<br /><br />Look on the back of the trim gauge. Should be a place for signal, ground and ignition....or a source for 12V DC.<br /><br />There is two black wires coming from the position indicator reostat on the engine. These would go to the signal and ground. Run a lead to the ignition post from a handy 12DC source.<br /><br />This should get it working.
dajohnson53
Re: Trim guage
Trim senders are variable resistance things - they have higher resistance in one position, low or zero in the other. There are basically two general types - one has higher resistance in the up position, one in the down. <br /><br />The good news, is that I believe that all OMC outboards trim senders, no matter what the year, have the same sender specs in terms of ohms up vs. ohms down. I'm not absolutely sure about that since there is variability between manufacturers as well as different eras for certain manufacturers. I'd just hook it up according to OBJ's advice and see if your engine's full up and down show accurately on the dial.<br /><br />I don't know how good the online info for Faria is, but I find the Teleflex website extremely valuable for general and specific info on gauges and senders, no matter what brand you're using. <br /><br /> http://www.tflx.com/ Browse around in the technical assistance and guage search menues, I think you'll find it interesting.<br /><br />The website also has tech info which can show you how to test both the gauge or sender. It's easy to do if you have rudimetnary understanding of a multi meter. Have fun, hope it works out.
nedskelly
Re: Trim guage
OBJ and D thanks for the info will fit the gauge and see if it works
OBJ
Re: Trim guage
Ratsack.....the trim sender has a certain amount of adjustment on it if the trim gage isn't right on. Just losen the mounting screws up with the engine trimmed all the way up and adjust the sender till the gage reads true.
nedskelly
Re: Trim guage
OBJ, Thanks for the help, the trim gauge is in and working, may need to be fine tuned as advised. Now to get onto the water
