Hi all, <br /><br />The Tilt and Trim on my1994 Johnson 120 has been working intermittently for a while now, it used to stop working only for a few pushes on the cowl or control box buttons, but now it has become worse and will not work for quite some time.<br /><br />I have done the test mentioned here to test the cowl buttons, but it still does not go up or down when I touch the wires together. So I don't think the cowl switch is the problem.<br /><br />I pulled the cover off the Juction Box and when I push the down cowl button I can hear the Relay clicking and when I push the up button there is no noise at all, in both cases the motor will not lift up or down. If I keep clicking the buttons all of a sudden it will decide to work and lift up and down.<br /><br />I pulled both Relays and the flat pins on both are covered in a black tary sealant stuff that looks like it has seeped from where the wires enter the plug that pushes on to the Relays.<br /><br />I have a couple of questions:<br /><br />1. Could this tary stuff that is on the flat Relay pins be causing the problem? ie. bad connections.<br />2. If so, is there a way to clean the stuff out from inside the plugs?<br />3. Could it be that both Relays are duds and should be replaced?<br />4. Or could there be another problem I should look for?<br /><br />Thanks, any help appreciated.<br /><br />Cheers Rosscoe
