farginicehole
- Joined
- Apr 15, 2003
- 482
I've been having an intermittent loss of spark to one or more cylinders (moves around - not always same cylinders). This engine has been extremely difficult to start after it has sat for more than a week or so. Once (maybe I say "if") it does finally start, you can shut it off and it will easily fire right back up. . . even if it only ran for a minute or so before turning the key off. My tach sometimes acts goofy too - sometimes works fine(?), sometimes cuts out completely, sometimes reads a LOT lower rpm than what my ears and the speed of the boat say the motor is turning. Last season, I replaced all six coils and plug wires "just because" they were old and I couldn't be sure the cracks in the insulation weren't shorting to ground. I have removed my flywheel and visually checked the stator, and didn't see any signs of it overheating or the oozing substance other threads have said to look for. I bought a Stevens PVA-1 to use with a Fluke to check the stator and sensor coil outputs as outlined in my Clymer manual. I also plan to test the rectifier per Joe Reeves' instructions in http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=28;t=019709#000000. I'm guessing the powerpack could be going south on me too, but I want to figure out if something else is the root cause of this before replacing it. Just wondering if any experts here have any advice for me, and can tell me if I'm going about this properly? Assuming I can get my ignition straightened out, are there other issues that could be contributing to my cold starting difficulties? Sorry for the long post, and thank-you very much in advance for taking the time to read and reply!
