crappie_condo
Thread starter- Joined
- Feb 25, 2005
- 32
Just had this sucker rebuilt because of a broken ring. I put the first 10 hrs. on it to break it in and the idle was OK. During the 11 to 20 hr. mark, the idle is getting worse. Took it back to the rebuild shop and they found a recirulation hose had popped off. Fixed the hose problem, but still not much change in the low idle sputter in gear. Also tilting the engine up and down affects the idle. Better idle up and worse down. It has metal bowls on the carbs. The Wrench has had the carbs and fuel pump off a couple of times looking for problems, but nothing yet. I am leaving it there til next week because he is going deeper into the front of the motor to double check a seal replaced during the rebuild. When we were doing a Lake test he popped off the bottom 2 plug wires while running and it did not affect the RPM as much as the top 2 cyl. The engine seems to load up at idle. Any input would be appreciated.. Thanks in advance...
