jeremyeasen
Thread starter- Joined
- Jun 20, 2002
- 72
This has been an ongoing saga, but its narrowed down so I thought I'd start a new topic. I found quite a bit of crud in my newer fuel/water separator filter so I changed filters. After nearly 3 hours of solid running at 4500 to 5000 I thought she was fixed. Then the alarm started chirping...fuel restriction. We made it home and I checked the filter. It was clean fuel, no crud. Next I will take a spare tank and bypass the filter to check this out, but before I do I'd like to know if its possible for these fuel pumps to "get tired" after long stretches of running. Everything else is great. FYI, no VRO and its not an overheat. Motor is 1994, with original pump. thank you all. By the way I've found that this restriction sensor has been very effective. It goes off about 5 minutes before the motor shows the effects of running out of fuel.
