Hi all,<br />I have a 2001 Johnson 150. I can easily do most of the sync & link procedure but come unstuck when it comes to ignition timing because you need the OMC Ignition Analyser (P/N 434017). This is really expensive.<br /><br />I'm aware of Joe Reeves method but I think the Quick Start feature complicates this on my motor. I've done a bit of research on this subject (there's an excellent book on ignition troubleshooting at www.rapair.com) and I don't think it would be too hard to build an electronic unit that does the same thing as the analyser (given that I have electronic skills).<br /><br />There are only 5 wires going to the optical ignition sensor on my motor. Two of these are power (one to power the LED), one ground and two signals which give pulses: once per motor revolution & seven times per revolution.<br /><br />Since the adjustment is done with the motor stationary, the ignition analyser must just be detecting the position at which the optical sensor switches from one state to the other (I presume).<br /><br />This may be a long shot, but has anyone else looked into this? Would be nice to come up with a circuit that does the same thing.
