71 johnson hydro electric 60 hp question
tomed01
Salute All<br />I have a Year: 1971<br />HP: 60<br />WOT RPMS: 5000<br />Hydro electric<br />My question is about the link for the spark advance which connects to the top of throttle arm and then to the spark advance linkage under fly wheel. ive tried ordering it from several places no one has it anymore so ive decided to make it from alluminum rod but can anyone tell me the length of the rod to the bends? and is this rod really needed?<br />Thanks All
alden135
Re: 71 johnson hydro electric 60 hp question
Hve you tried Twin Cities Outboards?
tomed01
Salute <br />Negative tried ishopmarine.com and lot of local marine venders.
alden135
TCO gets recomended a lot here for hard to find older parts. They have a web site.
alden135
Oh Ya... you don't salute a Non-Com :)
tomed01
Thanks !!lol<br />5 years in the 82nd abn youd think I would have remembered...lol <br />Dont salute me boy I work for a living!!
karrick
I've got the same model. I could get you measurements or whatever you need but I won't be able to relay the info you need until Monday morning. <br /><br />K
CATransplant
If you make it, and yes, you do need it, consider making it from mild steel rod, instead. The aluminum rod they sell in hardware stores doesn't like being bent all that much. I'm positive the original is steel.
tomed01
Thanks Guys<br />Yes would very much like the info Karrick and steel does seem the better way to go will do CA .<br />Thanks again !!!
karrick
sorry pal,<br /><br />Long weekend between a whirlwind trip to chicago and 6 hours at brookville. Completely forgot. I'll try my best 4 tomorrow
tomed01
ok , Thanks!<br />Hope to get her in the water this weekend....lol
tomed01
Hi Myoutboards<br />Ive emailed them hopefully they will have one...<br />Thanks
DHPMARINE
tomed01,<br /><br />I don't know where you are posting from,but if it is here in the USA,just go to your local OMC/BOMB dealer and order # 313700,now known as #395448.<br /><br />He'll have a minimum order of 5,so he may make you buy all 5 for a motor that old,but they list for less than $3.00 each.<br /><br />And after sync/link you'll be right on,and not 'in the zone'.<br /><br />DHP
tomed01
thanks dhp,<br />Will try the #s you gave i had 314165 was told it was 15.00 3 sounds alot better and im here in NC.<br />Thanks again
karrick
Sorry for draggin my feet. I assume this is the linkage piece you want. The stock piece is made of steel. Good luck<br /><br />
tomed01
Thanks Karrick<br />!!!!
