Help ID year 140 V4 rude. thanks
xikxak
Evinrude 140 (looper)def not crossflow. all blue,only id found is on silver plug G2351888.it was sold to me as 94ish. any info? thanks davexx <br />I cant even figure wher the gas line gets hooked up.never seen nothin like this before. help. I gotta get a manual :( :( <br />
<br />
<br />
<br />
<br />
xikxak
Re: Help ID year 140 V4 rude. thanks
Everybody out boating but me. where do I hook up the gas? thanks davexx
xikxak
Anyone ever see this before?in searching on the port side I found a little oblong label under the paint.when I peeled it off big letters were behind the lable saying "VOID VOID}after scraping the paint from the label it says mod no void void void then serial no also voids ,under that it says"Outboard marine Corporation".Any ideas,I,m baffeled. Thanks davexx
Bear
Exploded view for fuelpump at Ishopmarine <br /><br />Take a look at it and find out what parts you need. There is a few parts missing.<br /><br />Yes it looks 94ish. <br /><br />I have seen 'void' in another post. Don't know what that means.
xikxak
A few parts misssing from where,my motor? davexx
Dhadley
Looks like a good mix. The ignition is from 1988 to 1995. The cooling system is from 1985 to 1992. The throttle arm is from 1985-87. I cant be sure but it looks like there is a notch cut out of the head gasket tab sticking up. That means its a big bore 2.0 liter block. That was from 1988 & up.<br /><br />There are 4 fittings on the fuel/oil pump. Oil in (that little white sight glass), fuel in, the pulse hose (hooked to the block front half) and fuel/oil out on the top.
xikxak
Could this possibly be "commercial model" in checking the wiring diagram in seloc it shows trim & tilt button on starbord side of lower cowl and says "commercial only"Thats what I have.I have no harness coming out of engine for T/T switch.just trying to narrow it down.
Dhadley
That switch on the pan plugs into a harness that goes into the relay box. All the V4 loopers had it starting in 1989.
xikxak
Thanks Dhadley.
Dhadley
Youre welcome.<br /><br />Is there a notch in the head gasket tab?
xikxak
No I checked today,no notch
