40 HP Prop Shaft removal question...Hoping for a quick responce, working on it n
goosehntr
I am removing the prop shaft from a 40 hp johnson (1992) and have a question..Do i have to remove the drive shaft completly or just take the nut off of the pinion gear to get the prop shaft out? I have everything else out and did not want to go any further until i found out if i had to remove the drive shaft...how about the shift linkage? do I have to remove it?<br /><br />thanks<br /><br />Chad
denislajoie
Re: 40 HP Prop Shaft removal question...Hoping for a quick responce, working on
hey chad, dont quote me on this but im pretty sure you have to drop the lower unit cause the drive shaft spins a helicoidal gear which is constantly meshed with the prop output shaft
goosehntr
I have the lower unit off. I was wondering if i had to remove the drive shaft and shift linkage completly from the lower unit? thanks<br /><br />Chad
denislajoie
drive shaft yes, shift linkage, not sure, you ll know more once you re into it, but dont take apart more than you have to, start with the shaft and see from there
goosehntr
Thanks...heading back to the garage :)<br /><br />Chad
rwcreigh1
if you dont have one get a manual.it helps
