1978 85 hp Johnson no power
flhpi96
I have a 1978 Johnson 85 hp I have rebuilt the carbs and still I can't get any rpm's over 2,500. It idles and starts fine. I check the plugs after putting new ones in and it seems that one bank is not firing. I was going to change the power pak on that side it see if that was the problem. Any help?
Re: 1978 85 hp Johnson no power
If it was running fine before the carbs were rebuilt, and now it doesn't I would suspect the carbs. Perhaps the high-speed adjustment?<br />I am by far not an expert, it just seems like I read that those carbs have low speed and high speed adjustments.
PS;<br /> Read all the posting here and I am sure you'll find something relating to your issue. These forums are a treasure-trove on info, tips and tricks by mechanincs and stuff.
Cricket Too
What makes you think that the one bank isn't firing? Did you do a spark check?
flhpi96
I rebuilt the carbs because of the problem
flhpi96
Also the carbs are fixed jets no adjustments.
