red warning light
theard
i have a 1998 or 1999 20 hp 3 cyl. Evinrude that has a red light on the front of the motor next to the pull rope that comes on when I start the engine. It didn't do this the last time I took it out fishing. But when I hooked up the water hose to the "ear muffs" to run it in my yard after sitting up a few months, I noticed the light on when I started it up. I have no owner's manual as I bought it second hand. There is no warning buzzer accompanying the red light. It has oil injection. Could it be an oil injection warning? or is it a heat warning sensor that is getting a false reading? And yes, the water pump is working as I can see water coming out of the "pee" hole. :confused:
OBJ
Re: red warning light
Hey theard...welcome!<br /><br />Can you post a model number please? Something ain't computin' here. A model number will help.
theard
The model number is E25RMEDC. It's a 25hp, 3cylinder Evinrude motor. I also noticed that by the "red light" is a symbol that looks like a drip of oil....so I am assuming it is an oil injection warning light. I have oil in the reservoir and checked to see that the float in the reservoir wasn't stuck and all the wires from it are intact. Could it be a false reading from a sensor, possibly?<br />Also, any ideas where I could get an owner's manual for it?
angus63
You have a 1996 motor. Manual can be found at theoutboardwizard.com. Never saw a warning light on a 25hp motor before, sorry I can't help there.<br />Good luck
Cricket Too
25hp that has 3 cylinders, never heard of that before, you sure about that? The outboard wizard is good they had the original 1976 manual for my 70hp. There are also manuals here on iboats. Not sure about the oil light, but you should definitely get a manual to find out. Does it run the same as last season, just has a light on?
R.Johnson
You are looking at a low oil light, did you check the level in the oil tank under the engine hood?
