getting erratic spark
mikeyzx2
Hey ya'll I need some help here. I rebuilt the carbs, changed out all fuel lines on the motor, installed new sparkplugs, and just put all new coils on it. Before I did all this, it started up no problem and ran good, other than dropping RPMs at WOT. I found a couple of coils had cracks in the insulation so I went all out and replaced them. Now I can't get the sucker to even start, not even spark half the time. I pulled all the plugs yesterday and managed to get them all to fire but when trying to start it was like maybe one cylinder would pop but nothing. I did some tightening and such and I finally got it to fire today, so I thought it must have been a bad ground. It started up rough but after some popping and puffing it got it's act together. I stopped it and after a few minutes I got absolutely nothing and back to square one. What are some of the possibilities that I'm facing? Give me some ideas.<br /><br />Mike
mikeyzx2
Re: getting erratic spark
Oh forgot it's a 77 Evinrude 85hp V4. I did let it run for a couple minutes and restarted it fine but after it set for about five minutes it never even hinted of firing.
mjash
Sure you got them coil wires seated right mikey? I am having similar probs. Gonna get her on the water tomorrow to see if she is workin.
mikeyzx2
that's what I'm wondering myself Mark.....they are a pain in the lower end to get on the coil, the end with the boot isn't so bad.
OBJ
Mikey...take a small sharp punch and pre-start the hole in the spark plug lead. This will make sure the pin in the coil gets centered. Put a little lube on the wire and push it in with a pair of pliers. And don't forget the coil grounds....make sure they are clean and making good contact.<br /><br />And just one more thing.. :) ..Check the pins in the coils are straight. If the seem off center, use a small screwdriver to put them right.
mikeyzx2
Thanks OBJ I remember reading a similar post recently with a similar response from you. When you say "lube" are you meaning dielectric grease? I think I got some hiding around here somewhere. I guess these coils are notorious for being a pain to assemble. Thanks<br /><br />Mike
